I've let my love of shiny new QGIS plugins get the better of me, and I'm finding it difficult to remember which menu / submenu / panel that a given plugin is in. I'm using well over 100 now, and going on a purge usually means I find another use for the plugin I just removed...
So I thought I'd try to write a plugin to get that info so I could search for it. Things that the Plugin manager knows, plus (most importantly) how to locate it in the GUI.
Processing is great for finding a lot of the built-in qgis functionality, but it doesn't find plugins which weren't written to make use of its framework.
Looking at the answer to listing installed plugins via pyqgis I was able to get a list of plugin names.
There seems to be a class, QgsPluginRegistry, which looks promising in the C++ code, but I can't find a SIP defintion file for that, so I don't think this class is exposed to python.
Using a bit of tracing through the QGIS source, I was able to write a short snippet to sniff the configuration files for the plugins
for x in qgis.utils.findPlugins("/home/steven/.qgis2/python/plugins"): # gets a (name,ConfigParser) tuple print "_"*80 print x[0] # plugin name for key in x[1].options('general'): print "\t%s = %s" % (key, x[1].get('general',key)) This gives me access to the same info as the qgis plugin manager... changelogs, authorship, category and so on.
qgsAffine name = Affine Transformations qgisminimumversion = 2.0 description = Apply affine transformations to selected geometries. version = 1.0.2 author = Mauricio de Paulo and Erik Timmers email = [redacted] changelog = [snipped] experimental = False deprecated = False tags = homepage = [redacted] repository = [redacted] tracker = [redacted] icon = icon.svg category = Vector What it doesn't tell me is where, exactly, is it in the menu structure? Can this be got from pyqgis in a clean way?
Or to find this, do I need to start sniffing round the Qt GUI classes or writing python parsers (doable, but seems a bit over the top?) The category value (vector, raster etc) helps narrow the search, but there are plenty of plugins (e.g. MMqgis) which create their own menus.
