Is there a way to get Z value from 3D multipoint shapefile in QGIS?
Is there a way to get Z value/height/altitude from 3D multipoint shapefile in QGIS? All I found is way through SpatiaLite or PostGIS as explained here:
http://faunaliagis.wordpress.com/20...apefiles-z-values-to-the-table-of-attributes/
But conversion multipoint to point using Vector/Geometry tools/Multipart to singlepart drops the Z value. I opened DB manager, select DB and run SQL command in SQL window:
update tablename set columnname = st_z(st_pointn(geom,1)
In my case:update lidar_pts set z= st_z(st_pointn(GEOMETRY,1))
First there was missing ")" at the end, second: no such column: geom. So I changed it to "GEOMETRY" which end up running but all z values become Null.
Is there a better/other way in QGIS 2? Or at least is there a way to convert multipoint to point directly in SpatiaLite so it will keep z geometry?
