Is there a way to copy attributes from a point layer in an overlaying polygon layer?
I'm working with an agricultural experimental setup of 450 areas. Each area is represented of a Polygon in ArcGIS and additional with a point Layer. I determined the specific ID for each point but I dont want to do the same work again for the polygons. Is there a way to transfer the IDs from the points to the polygons? The points are always within the polygons but not always exactly in its centre, so that I cannot link the shapes by calculated coordinates of the polygons cendroid.
