This is my problem:I have an arcpy script that finds the XMax, XMin, YMax, and YMin of a polygon. It shows the results in feet, but I want them to be in decimal degrees.
In ArcMap I can change the data frame's display units to decimal degrees. But every time I run my script it shows the numbers in feet again.
Is there a solution for this in arcpy?
