Is there any projection that I can use the gives me easting northing values that are locally consistent?
By locally consistent I mean:
To be more general:
What I'm trying to do is render a 3D scene with geographically localized objects whose 3D models are to scale and I need the objects to be correctly positioned in relation to each other.
Is there a way to solve this problem for every "small" area of the world or am I better off asking the user for the best projection for "small" area?
Does doing this correctly involve a scale factor and this common projection?
- For any pair of objects inside a square with 5km side; if I do distance = obj1.Position - obj2.Position, distance is the same as the actual distance between the pair.
To be more general:
