Is the result of "generalization" algorithm the same every time using it in ArcGIS?
I have a database with roads, and i update it oftenly. For another department we give them the same database but generalized so they can fit the forest to the roads.
I wanted to know if you use generalize on the same database several times, do you get the same results regarding lines that haven't change since?
I mean, do the unchanged roads have still the same geometry and vertex number so they still fits with the forest from the previous work?
