I've used the following ESRI snippet to Convert the display extents in Pixels (at the current map scale) and then return out the map units.
public System.Double ConvertPixelsToMapUnits(ESRI.ArcGIS.Carto.IActiveView activeView, System.Int32 pixelUnits){ if(activeView == null) { return -1; } //Get the ScreenDisplay ESRI.ArcGIS.Display.IScreenDisplay screenDisplay = activeView.ScreenDisplay; //Get the DisplayTransformation ESRI.ArcGIS.Display.IDisplayTransformation displayTransformation = screenDisplay.DisplayTransformation; //Get the device frame which will give us the number of pixels in the X direction ESRI.ArcGIS.Display.tagRECT deviceRECT = displayTransformation.get_DeviceFrame(); System.Int32 pixelExtent = (deviceRECT.right - deviceRECT.left); //Get the map extent of the currently visible area ESRI.ArcGIS.Geometry.IEnvelope envelope = displayTransformation.VisibleBounds; System.Double realWorldDisplayExtent = envelope.Width; //Calculate the size of one pixel if(pixelExtent == 0) { return -1; } System.Double sizeOfOnePixel = (realWorldDisplayExtent / pixelExtent); //Multiply this by the input argument to get the result return (pixelUnits * sizeOfOnePixel);}and then this to check if the snapping is within tolerance ITolerance which is in Pixels(Example 10 pixels) :
Double dblToleranceX;dblToleranceX = snaptolerance(ITolerance);// call ESRI Snippet dblProximity = dblToleranceX;ouble dblToleranceY = dblToleranceX;pInputpoint = gpMxDocument.ActiveView.ScreenDisplay.DisplayTransformation.ToMapPoint(intX, intY);pRectangle.PutCoords(pInputpoint.X - dblToleranceX, pInputpoint.Y - dblToleranceY, pInputpoint.X + dblToleranceX, pInputpoint.Y + dblToleranceY);pSpatialfilter.SpatialRel = esriSpatialRelEnum.esriSpatialRelIntersects;IFeatureClass pFeatureClass = gpFeatureWorkSpace.OpenFeatureClass(strFeaturecls);pSpatialfilter.Geometry = pRectangle;pSpatialfilter.GeometryField = pFeatureClass.ShapeFieldName;pFeatureCursor = pFeatureClass.Search(pSpatialfilter, false);pFeature = pFeatureCursor.NextFeature();if (pFeatureClass.FeatureCount(pSpatialfilter) < 1) { MessageBox.Show("Snapping is not within tolerance"); return; }The code work perfectly on NAD83(decimal degree) but does not work when Changing the data frame's coordinate system to NAD 83 UTM Zone 11N (Meters).
Appreciate your help if you can figure out a way around this issue in order to make the code work for these kind of situation .
