I am building an MS Access database and am a beginner but have experience with VBA coding in excel (including the generation of KML files).
In theory, is it possible to import a KMZ file in to access, compare data (unique numbers) from the KMZ with tables within the access database, amend the KMZ data (change color codes for polgygons where the data matches), and regenerate the KMZ (or as KML) for display in google earth?
I have reviewed the KMZ file and the unique numbers I require are stored in the placemark description, with duplicate information stored within "Extended data" tags under "Simple Data".
