I'm using ERDAS 2014 and I upgraded from ERDAS 2013.
I am doing a lot of band indices for various kinds of such as clay, ferrous, Mineral composite and so on.. from landsat 8.
Using the indices in ERDAS 2014, the problem is that it does not detect IR/R (infrared divided by red) if you change the sensor to Landsat 8 MS but if you look at other landsat such as 4 TM and 5 TM.
I can see that the formula for IR/R is IR/ Red which is Band 5 / Band 4. This band is for Landsat 8.
OR would I have to take a BAND 5 and BAND 4 separately and run the formula in ERDAS ?
Anybody have that same problem ?
