[h=2]Introduction to ArcGIS Using ESRI ArcView 10.1 and VT GIS Data[/h]
CHAPTER 1 Tour of ArcMap Open ArcMap Docking toolbars Add Data Explore the Table of Contents Use the Tools Toolbar to Navigate Within Data View Use the Identify Button
CHAPTER 2 Planning Your Map Project Scope Audience Medium Data sources
CHAPTER 3 Acquiring Data Add Data from ArcGIS Online Explore VCGI’s Vermont GIS Data Stream Data via VCGI’s Web Map Service (WMS)
CHAPTER 4 GPS Data Import .GPX Data Re-Project Data Add X,Y Coordinate Data to ArcMap Save X,Y Coordinate Data as a Point Shapefile
CHAPTER 5 ArcCatalog Open ArcCatalog as a Stand-Alone Program Open ArcCatalog Within ArcMap Dock the ArcCatalog Window Add Data from ArcCatalog Manage Data in ArcCatalog Optional: View Datasets using Windows Explorer
CHAPTER 6 Attribute Tables Use Select Features Tool Set Selectable Layer(s) Open and Dock an Attribute Table Select Features in an Attribute Table Select By Attributes Select By Location
CHAPTER 7 Joining Tables Open ArcMap Join a Layer with a Table Save Joined Tables as a New Shapefile
CHAPTER 8 Edit Data in ArcMap Edit Features Save Your Edits Reshape an Existing Polygon Digitize Abutting Polygons Create a New Shapefile
CHAPTER 9 Symbolizing Data Symbolize Using Unique Values Change Line Symbology Symbolize Using Graduated Color Optional: Symbolize with Graduated Symbols
CHAPTER 10 Working With Labels Add Graphic Labels Use the Label Tool Use Dynamic Labels The Label Manager The Maplex Label Engine Convert to Annotation Use a Label Expression Save a Layer File
CHAPTER 11 Introduction to Geoprocessing: Dissolve and Buffer Set Up Map Document Select By Attributes Select By Location Export to New Layer Summarize Data by an Attribute Dissolve Boundaries Calculate Acreage Buffer Polygons
CHAPTER 12 Introduction to Geoprocessing: Clip and Spatial Join Set Up Your Map Document Clip a Data Layer Select By Location Create an Attribute Flag Write a Definition Query Clip a Layer Perform a Spatial Join Evaluate Your Results
CHAPTER 13 Layout View Explore Layout View Add a North Arrow and Scale Bar to your Layout Add a Legend to your Layout Insert a New Data Frame Copy Layers between Data Frames Change the Active Data Frame Arrange Data Frames in Layout View Insert Text Adjust Legend Text in the Table of Contents Add an Extent Indicator to a Data Frame Tips for Working with Legend Properties (v.10.1) Tips for Working with Legend Properties (v.10 or earlier) Tips for Working with Legend Properties (any version) Optional: Align Elements in a Layout
