I have a problem with my interactivity and I can't solve alone. When mouse hover are on any point I would like show by console.log any column of my dataset.
With my code, only show me cartodb_id.
var map;function init(){ // initiate leaflet map map = new L.Map('cartodb-map', { center: [40,-98], zoom: 4 }) L.tileLayer('https://dnv9my2eseobd.cloudfront.net/v3/cartodb.map-4xtxp73f/{z}/{x}/{y}.png', { attribution: 'Mapbox Terms & Feedback' }).addTo(map); var layerUrl = 'https://mcnb.cartodb.com/api/v2/viz/85aef586-5c57-11e5-9915-0e73ffd62169/viz.json'; // change the query for the first layer var subLayerOptions = { sql: "SELECT * FROM mcnb_dev", cartocss: "#example_cartodbjs_1{marker-fill: #109DCD; marker-width: 5; marker-line-color: white; marker-line-width: 0;}" } cartodb.createLayer(map, layerUrl) .addTo(map) .on('done', function(layer) { layer.on('featureOver', function(e, pos, pixel, data) { // print data to console log console.log("Event #" + data.cartodb_id + ", Name " + data.name + ", Clase: " + data.class+ ",Incertidumbre(m.) " + data.coordinateuncertaintyinmeters ); }); // change the query for the first layer var subLayerOptions = { interactivity: "cartodb_id,class,coordinateuncertaintyinmeters", sql: "SELECT * FROM mcnb_dev", cartocss: "#example_cartodbjs_1{marker-fill: #109DCD; marker-width: 5; marker-line-color: white; marker-line-width: 0;}" } var sublayer = layer.getSubLayer(0); sublayer.set(subLayerOptions); // sublayer.infowindow.set('template', $('#infowindow_template').html()); sublayer.on('featureClick', function(e, latlng, pos, data) { alert("Hey! You clicked " + data.cartodb_id); }); }).on('error', function() { //log the error });} SubLayer featureClick works but featureOver not.
Thanks a lot! Sorry for my english
