Install Trouble: TinyOWS with WFS-T
I've been trying to install a tinyows with wfs-t server to compare the project with OSM. OSM was a rather easy install but I'm running into trouble with tinyows because of fragmented documentation. I've followed these two guides for the install:
http://mapserver.org/tinyows/openla...apserver.org/tinyows/serverinstallation.htmlA couple of problems with the guide:
1.) At the end of sudo make install, it leaves instructions to copy a tinyows binary to cgi-bin, and to copy tinyows.xml to /etc/. Well there is no tinyows.xml file except for in the demo directory.
2.) On part 3 of the first link it tells you to edit /usr/local/tinyows/config.xml
My tinyows install resulted in no tinyows folder in /user/local. Going into my original tinyows folder there is still no config.xml. Going into /tinyows/demo/ shows a tinyows.xml file that looks similar to the config but it can't be the same because its referenced in another instruction.
3.) After so many attempts of rearranging and editing files I always come back to one error running a test command as instructed:
.//tinyowsError:
Connection to database failed I am really new to GIS and have little experience with many of these dependencies needed for such a project. If any one has a better guide, instructions, or help to get this working that would be amazing.
