Impossible to define the shapefile projection properly
I have been struggling for hours to figure this out.I downloaded some dataset from Hot Export. By default they don't have any projection or coordinate system defined. The only thing I can see is the Feature Extent with values such as: Max Y "1117781,..."I used ArcCatalog to define the projection: right-click on the property of the shapefile > XY Coordinate System tab > then I select the GCS as WGS84 (Projected Coordinate System not used here).The problem appears when I open the data into ArcMap. Instead of modifying the Feature Extent in decimal degree values, I still have 1117781,... but only the unit has changed (dd). I can't alignh these dataset with other dataset having the same GCS. It's like if the feature extent is blocked into "meter" values while other dataset working fine have normal dd values. I really don't get what is going on... Any help would be sooo welcome! Thank you so much in advance!
