Import functions in python Add-In logic script
I am running into an error. I have a set of functions which I want to import in the python Add-In script at the time of execution, but when I built Add-In with "import stats" line then tools are unresponsive. Any suggestions whether it is possible to import functions in the Add-In script?
import arcpyimport osimport pythonaddinsimport statsoptfolder = "C:/temp"class AoI(object):"""Implementation for rectangle_addin.tool (Tool)""" def __init__(self): self.enabled = True self.cursor = 5 self.shape = 'Rectangle' os.makedirs(optfolder) def onRectangle(self, rectangle_geometry): """Occurs when the rectangle is drawn and the mouse button is released. The rectangle is a extent object.""" extent = rectangle_geometry arcpy.Clip_management(r'C:/temp/ras', "%f %f %f %f" %(extent.XMin, extent.YMin, extent.XMax, extent.YMax), optfolder + '/ras1', "#", "#", "NONE") arcpy.RefreshActiveView()
