IF THEN statements in ArcGIS Field Calculator
Good morning all,I'm not sure if this would be best handled in vbscript or python, and unfortunately I'm less than novice at both so I'll take any help I can get from the exchange.
I'm trying to take my streets layer and remove the "type" field for a certain set of street names. Any street named "Avenue A", "Avenue B", Avenue C" and so forth would need the "TYPE" field emptied out. But all other streets and street types would remind.
A little explanation as to the why may help you understand my plight a little better: We have an emergency response software at my municipality that uses both the prefix, subname, and type to display the streets data, as well as, track calls and statistics for each street. All streets display properly except for the "Avenue A" type streets which show up "Avenue A AVE". Any other AVE type street displays properly, for example: Baltic AVE, Crawford AVE, etc. But the "Avenue (letter)" streets will not with the "TYPE" field populated. Hope this makes sense.
So what I am needing is a field calculator script that will search for any [SUBNAME] "AVENUE #" street and blank out the [TYPE] field for it. I tried a little SQL with my inadequate knowledge of VBscript to generate the below (no it didnt work):
IF [SUBNAME]="AVENUE *" THEN REPLACE([TYPE],"AVE","")
