Identify polygons greater than n-th percentile and perform further analyses using arc
My goal is (1) to identify tracts that are above the 99 percentile of a variable (xvar), (2) to dissolve contiguous tracts by summing a variable (yvar), and (3) to get the coordinates of the centroids (longitude and latitude) of the merged polygons.
At the very first stage for picking the above-99th-percentile tracts, I have got some errors. The following is my current work:
import arcpyimport numpy as npinput = r'D:\7362.shp'myarray = arcpy.da.FeatureClassToNumPyArray(input, ('xvar'))print myarray# Printed output:# [(5.204770523,) (8.6471839055,) (2.1095837756,) ..., (1.4788840302,# (6.24183499,) (3.6710648163,)]p99 = np.percentile(myarray, 99)# use cursor to create the indicator field# Do I have to create the abovep99 field in the first place???with arcpy.da.UpdateCursor(input, ['xvar','abovep99']) as cursor: for row in cursor: if row[0] > p99: row[1] = 1 else: row[1] = 0 cursor.updateRow(row)The error messages in the percentile calculation p99 = np.percentile(myarray, 99) are following:
Traceback (most recent call last):File "", line 1, in p99 = np.percentile(myarray, 99)File "C:\Python27\ArcGIS10.3\lib\site-packages\numpy\lib\function_base.py", line 3096, in percentilereturn _compute_qth_percentile(sorted, q, axis, out)File "C:\Python27\ArcGIS10.3\lib\site-packages\numpy\lib\function_base.py", line 3132, in _compute_qth_percentilereturn add.reduce(sorted[indexer]*weights, axis=axis, out=out)/sumvalTypeError: unsupported operand type(s) for *: 'numpy.ndarray' and 'numpy.ndarray'So, my question is how to fix this problem for the percentile calculation? Plus, would you please provide some help for step (2) and (3)? Thank you very much!
