I can't load attachments with "Add Attachment" tool utilizing "Generate Attachment Ma
Problem with running Add Attachments tool, and Generate Attachment Match Table tool. Please help. Information below.
I am running ArcGIS 10.1 for desktop advanced licenses.
I can and have added attachments via enabling attachments, starting edit mode, opened the attachment manager and adding files for each polygon, one at a time. However, I have several more thousand polygons to go and was looking to speed the process up by using a Match Table and Add Attachments to features tool.
What I have done so far: Renamed multiple photos within the same folder to match attributes within Feature class table field, “future_projects_area” Futprj. Photos have names like pic.jpeg, pic(1).jpeg….
Enabled attachments from within ArcCatalog.
Ran “Generate Attachment Match Table”
I have created a match table with the “Generate Attachment Match Table”.
1. Input Dataset: is feature class within DB that I renamed photos to match. 2. Input Folder: is location on my computer where photos are kept 3. Output match Table: I cut and paste from ArcCatalog the absolute path back to input dataset DB and name table to same as input dataset feature class, “future_projects_area_Match” 4. Key Field: Name of attribute table field that contains names of projects I have renamed photos to, “futprj”. 5. Store Relative Path: I ran this tool both ways, with relative paths and absolute paths. When I ran with relative paths it caused issues with “Adding Attachment” to features tool, since it only contained the name of each photo. When I ran with absolute paths the complete paths were shown.
The generated Match Table shows up in ArcMap and inside chosen database.
The problem comes when I try running the “Adding Attachment” to features tool.
  1. Input Dataset: is feature class within DB to have attachments added
  2. Input Join Field: Since I can pick any attribute field I choose Object ID since the Match table has two fields, the first are the Object ID within “future_projects_area” attribute table which each photo matches based on naming convention I explained earlier.
  3. Match Table: I choose the match table created by running Generate Attachment Match Table.
  4. Match Path Field: If I load the match table with relative path, I choose the workspace where the attachments are kept. If I load match table with absolute path, then I leave the “Working Folder” empty.
The tool runs but no attachments are added, or I get the following error…
Cannot Add file....to feature with OID=1So on and so on.
