HP EliteBook 8540w Mobile Workstation
Overview
Portable Powerhouse. Workstation-caliber graphics and performance with a 15.6-inch diagonal HD display and an integrated numeric keypad, and a highly mobile and rugged design.
Features
High performing mobile workstation:
• Maximize onscreen performance with workstation-caliber graphics. Choose from the NVIDIA Quadro FX 880M or 1800M or the ATI FirePro M5800 with 1 GB of video memory. See how one rock star uses the HP Mobile Workstations to create and edit videos.
• Produce accurate color on the 15.6-inch diagonal LED with optional HP DreamColor display technology that supports over 1 billion active colors.
• HP Performance Tuning Framework allows you to configure and tune your HP Mobile Workstation for optimal performance.
• The latest technologies. Share information with fast transfer speeds using two USB 3.0 ports. Connect to external displays and get sharper, deeper images with DisplayPort.
Industrial design debuts in gunmetal:
• Starting at only 6.4 lb. (2.89 kg) with a 1.28-inch height in front, this Mobile Workstation, with a gunmetal finish, combines premier design with rugged construction to not only look stunning, but also to protect your notebook.
• Passes rigorous MIL-STD 810G testing. Designed to meet tough military standards (MIL-STD 810G) for vibration, dust, humidity, altitude, and high temperature.
• Spill-resistant keyboard with drains. Help protect sensitive electronics and key components from minor spills that might otherwise cause system failure with this thin layer of Mylar film under the keyboard.
HP Professional Innovations:
• HP Power Assistant lets you take control of your notebook PCs reported power consumption! This tool allows you to conserve power, stretch battery run-time, accurately monitor your reported power needs and report workforce power consumption.
• HP QuickLook 3 provides quick access to email, calendar, contacts and tasks at the touch of the button without long boot-up time. HP QuickWeb grants access to the web in seconds…even if your notebook is turned off.
مرفق المواصفات الفنية للجهاز:
http://h10010.www1.hp.com/wwpc/pscmisc/vac/us/product_pdfs/HP_Elitebook_8540w_Datasheet.pdf
متوسط سعر الجهاز:
$ 1,349
تحياتي
