Can anyone show me a step by step example on how to use Sharpmap to display MS SQL server spatial data using C# as the programming language?
Please note I have exploit some of the example online but nor seem to be displaying data from MS SQL server 2008.
using System; using System.Collections.Generic; using System.ComponentModel; using System.Data; using System.Drawing; using System.Linq; using System.Text; using System.Windows.Forms; using System.Data.SqlClient; using SharpMap; using SharpMap.Geometries; using SharpMap.Layers; using SharpMap.Data.Providers; namespace sqlcnx { public partial class Form1 : Form { // we start with the connection string static string connstr = "user id=Youssef;password='';"+ //user id = name of your PC and because I use windows authentification I don't need passowrd "server=YOUSSEF-PC\\SQL;"+ //write your PC name + \\SQL (my PC is YOUSSEF) "Trusted_Connection=yes;"+ "database=test;connection timeout=10"; //my database name is 'test' , the connection timeout is the time in second that the proram will waite for the server to connect before generating an exeption SqlConnection myConnection = new SqlConnection(connstr); Map map; VectorLayer vly= new VectorLayer("vly", new SharpMap.Data.Providers.SqlServer2008(connstr, "quartier", "shape", null)); // 'quartier' is the name of the table in my database and 'shape' represente the geometry column in that table public Form1() { InitializeComponent(); } private void Form1_Load(object sender, EventArgs e) { map = new Map(pictureBox1.Size); // we give the map the pictureBox size, don't forget to add a pictureBox to your form in the designer
vly.Style.EnableOutline = true; vly.Style.Outline = Pens.Black; vly.Style.Fill = Brushes.Red; //the style of our vectorlayer color contour ..etc map.Layers.Add(vly); // add layer to the map map.ZoomToExtents(); //zoom to extentto see all the map map.BackColor = Color.White; pictureBox1.Image = map.GetMap(); //affect the map to the pictureBox } } }
