How to use map composer in a stand-alone script?
I'm trying to follow the map rendering section from the pyqgis cookbook, but I'd like to test this as a standalone application. I can do the first part, using simple rendering, but I'm a bit stuck doing the second example using the map composer as a standalone script.
Here is a standalone example for the bit I can do:
from qgis.core import *from qgis.gui import *from PyQt4.QtCore import *from PyQt4.QtGui import *from PyQt4.QtXml import *QgsApplication.setPrefixPath("/usr/", True)QgsApplication.initQgis()fh = open("eg.csv","w")fh.write("""x,y,name153.0278, -27.4679, Brisbane144.2500, -23.4500, Longreach145.7753, -16.9256, Cairns""")fh.close()uri = "eg.csv?delimiter=%s&xField=%s&yField=%s" % (",", "x", "y")layer = QgsVectorLayer(uri, "eglayer", "delimitedtext")QgsMapLayerRegistry.instance().addMapLayer(layer)img = QImage(QSize(800,600), QImage.Format_ARGB32_Premultiplied)color = QColor(255,255,255)img.fill(color.rgb())p = QPainter()p.begin(img)render = QgsMapRenderer()lst = [ layer.getLayerID() ] # add ID of every layerrender.setLayerSet(lst)rect = QgsRectangle(render.fullExtent())rect.scale(1.1)render.setExtent(rect)render.setOutputSize(img.size(), img.logicalDpiX())render.render(p)p.end()img.save("render.png","png")What I'd really like to do is the same, but use QgsComposition, and save as for example pdf. The cookbook says:
When using composer in a standalone application, you can create your own map renderer instance the same way as shown in the section above and pass it to the composition.
This bit I couldn't do, all my attempts either get an empty map, or a segfault.I'm running linux mint 13, using qgis 1.8.0. It would be great if someone could show me how to modify the simple example to one that uses the composer.
