How to use "context" in rasterio?
Another rasterio follow-up question, after questions on reading and writing rasters. I've successfully made and reprojected an output layer, but while trying to use the overview module to build pyramids, I found I don't understand something fundamental: the ctx parameter of the function.
def overview(ctx, input, build, ls, rebuild, resampling): By a Google search, I found that ctx means "context" and that there's a module named context in click library used by rasterio. I got stuck here: further searching shows "context" only in other contexts. The only useful hints I found here: info.py and test_rio_info.py files in the rasterio repository. I'm not good enough to be able to reverse engineer the ctx format expected by the overview function from these libraries (not sure whether it is possible).
So I need a good manual explaining contexts as used in rasterio, either as an answer or as a link with some summary. How to produce/get them, what exactly do they mean (do they have any use besides passing data into functions?), what are their components (if any) etc.
