How to update Field Mappings Parameter on table selection in Python ArcToolbox
I am building a python toolbox with ArcPy and would like to associate an input feature class parameter with a field mapping, so that once user selects the input feature class the field map populates with the input fields.
I have tried;
  • fieldMapParameter.addTable(feature_class_parameter.name) in the updateParameters method but throws error ParameterObject: Get attribute: addTable does not exist
  • Setting fieldMapParameter.parameterDependencies = [param1.name] doesn't seem to have an effect.
    def getParameterInfo(self): """Define parameter definitions""" feature_class_parameter = arcpy.Parameter(displayName="Input_Table", #0 name="fc_settlements", datatype="DEFeatureClass", parameterType="Required", direction="Input") fieldMapParameter = arcpy.Parameter(displayName="Primary Settlement Fields", #1 name="primary_fieldmap", datatype="GPFieldMapping", parameterType="Optional", enabled=True, direction="Input" ) fieldMapParameter.parameterDependencies = [feature_class_parameter.name] # Doesn't seem to work params = [feature_class_parameter,fieldMapParameter] return paramsdef updateParameters(self, parameters): if parameters[0].altered: parameters[1].addTable(parameters[0].valueAsText) # Fails with method not found return
Full Toolbox
How do I associate these two parameters so they work like field mapping for the native tools such as Merge/Append etc ?
