I installed CartoDB on a digital ocean instance of Ubuntu 12.04. I am able to log in and import data. Table view is fine, but map view does not show tiles with the message "There is a problem with your connection". I assume this means problems with the Windshaft tile server.
Windshaft installs ok:
git clone git://github.com/CartoDB/Windshaft-cartodb.gitcd Windshaft-cartodbgit checkout masternpm installbut make check fails; nine failing tests with two primary errors:
AssertionError: "2.1.0" == "2.1.1"and
Uncaught Error: listen EADDRINUSE at errnoException (net.js:769:11) at HTTPServer.Server._listen2 (net.js:909:14) at listen (net.js:936:10) at Server.listen (net.js:993:9) at dns.js:71:18 at process.startup.processNextTick.process._tickCallback (node.js:244:9)The only thing I changed in config/environment/test.js was to set Mapnik version to 2.1.1.
I've posted the full output of make check here:http://pastebin.com/CWSfijR8
Any ideas on what I'm not configuring or installing correctly? Or how else to troubleshoot these errors?
(follow up and update from question originally posted in CartoDB google forum)
