I have two lists of coordinates which are showing the same points but in different coordinate systems. I need to find the corresponding points in two datasets using distance but as they are in different coordinate systems, it is impossible. on the other hand, the coordinate systems are not known so that I can use a geographic transformation. Can I use Affine or projective transformation by extracting few tie points between two datasets?
