I wrote some code that basically loops over all features in a shapefile with Fiona in Python, doing some things, calculating some things, etc.
I found that it would exit the for loop prematurely, depending on the data set I fed it. I found that it would work fine if I removed some code that (to me) has nothing to do with the loop we are in. This is my first attempt at GIS with Python, so I might be doing some newbie mistage with data structures I guess?
Below is a minimal example using Natural Earth data which you can grab at http://www.naturalearthdata.com/htt...d/110m/cultural/ne_110m_admin_0_countries.zip
import fionafrom shapely.geometry import shape, Pointdef find_containing_area(point, collection): for record in collection: geometry = shape(record['geometry']) if point.within(geometry): return record return Nonewith fiona.open('/tmp/ne_110m_admin_0_countries.shp', 'r') as source: for admin_record in source: properties = admin_record['properties'] print(properties['name']) # in my original code, i created a point related to the admin_record point = Point(0,0) # if the following line exists, the loop will stop after the first # admin_record in this example. In my original code, it stopped # after just few records, not the first one though. containing_area = find_containing_area(point, source)If I run it, it prints "Afghanistan" instead of the whole list of ~177 names. If I comment out the last line, it prints them all as intended.
My only guess is that someone an iterator is passed along with the collection? The only hint in the documentation that I found is "Fiona’s Collection is like a Python file, but is iterable for records rather than lines." which does help stupid-me not very much. http://toblerity.org/fiona/manual.html#data-model
edit: I have tried to copy the collection and pass the copy to the function instead, got the same bevahiour:
newsource = source[:]containing_area = find_containing_area(point, newsource)
