The attached image shows two different forest openings. Each opening has the following layers associated with it:
How can I stack these rasters so that they are centered on the legacy tree in order to perform the raster algebra?
Edit:
As @Alexandre pointed out, the solution was to georeference the rasters based on X.
- Point shapefile 1 = A red X which represent a large "legacy" tree in the gap
- Point shapefile 2 = White points that indicate sapling locations
- Raster Layer = A kernel density estimate of the magnitude per unit area of point shapefile 2
Edit:
