How to split zAware polyline by points programmatically with C#?
I'm trying to split a polyline by the boundaries of a polygon using IPolyCurve2.SplitAtPoints using C#.The polyline I'm trying to split is zAware and holds elevation values at a regular interval.After splitting the polyline I would obviously like to get the different parts and save them as new features in my feature class, then deleting the original one.The problem is that when I try to set feature.shape to the geometry in my geometry collection made up of all the polyline parts, I get the error message that the geometry has no Z values.
Does anybody know how to solve this issue? I've looked around in the forum but all I found was code that doesn't deal with polylines that hold Z values.
Here is the code I'm using, passing in the original polyline, the point collection that holds all the intersection points with the polygon and the original feature class I create new features in.
public void SplitPolylineFeature(IFeature pPolylineFeature, IPointCollection pSplitPointCollection, IFeatureClass pFeatureClass) { //split the feature, each split makes a new part IEnumVertex pEnumVertex = pSplitPointCollection.EnumVertices; IPolycurve2 pPolyCurve = pPolylineFeature.Shape as IPolycurve2; IEnumSplitPoint pEnumSplitPoint = pPolyCurve.SplitAtPoints(pEnumVertex, true, true, -1); object Missing = Type.Missing; if(pEnumSplitPoint.SplitHappened) { //new geocoll for polycurve IGeometryCollection pGeometryCollection = pPolyCurve as IGeometryCollection; //loop through the parts of the split polyline for(int intPartCount = 0; intPartCount < pGeometryCollection.GeometryCount; intPartCount++) { IGeometryCollection pLineGeoColl = new PolylineClass(); IGeometry pGeometry = pGeometryCollection.get_Geometry(intPartCount); //IZAware zAware1 = (IZAware)pGeometry; //zAware1.ZAware = true; pLineGeoColl.AddGeometry(pGeometry, ref Missing, ref Missing); IFeature pFeature = pFeatureClass.CreateFeature(); pFeature.Shape = pLineGeoColl as IGeometry; //code crashes here: Geometry has no Z values pFeature.Store(); } } pPolylineFeature.Delete(); }
