How to split kml file or extract Placemarks?
I have a file of state 2001 assembly districts outlines, from http://goo.gl/dJPyx in Mapinfo MIF format. I've created a kml file from that using ogr2ogr. These are the outlines of each assembly district. In the kml file each assembly district outline is inside a Placemark tag. I want to put the kml outlines in Google Fusion Tables but I need them split up so that each assembly district outline (Placemark) is in a separate kml file.
It looks like I might be able to do it with xslt but I was wondering if there is a more direct way to do it. Or perhaps split the mif file first.
I'm also worried about splitting the xml file using xslt because there are a bazillion coordinates, as one very very long line, between the coordinates tag down inside the Polygon tag.
