I want to know linestrings (epsg:4326) length in meters instead of degrees.I know that I can use proj4 for that.
Here is my code, if you interested.
project = partial( pyproj.transform, pyproj.Proj(init='EPSG:4326'), pyproj.Proj(init='EPSG:3395'))project2 = partial( pyproj.transform, pyproj.Proj(init='EPSG:3395'), pyproj.Proj(init='EPSG:4326'))def distance_in_meters(linestring): return transform(project, linestring).lengthdef interpolate(distance, linestring): current_ratio = 0 points = [] step = distance / distance_in_meters(linestring) while current_ratio < 1: point = linestring.interpolate(current_ratio, normalized=True) current_ratio += step points.append(point) return pointsdistance_between_points = 249.67total_distance_in_meters = distance_between_points * 5class TestInterpolate(TestCase): def test_interpolate(self): with open("linestring.json", 'r') as f: s = shape(json.load(f)) points = interpolate(10, s) l = LineString(points) self.assertEqual(distance_in_meters(l), total_distance_in_meters)And here is linestring that I use for tests.
{ "type": "LineString", "coordinates": [ [ 37.6232398, 55.7615482 ], [ 37.6262633, 55.7606701 ], [ 37.6232398, 55.7615482 ], [ 37.6262633, 55.7606701 ], [ 37.6232398, 55.7615482 ], [ 37.6262633, 55.7606701 ] ]}What I've done is I've taken coordinates of two points from google maps and measured distance between them also in google maps.Than I've duplicated it several times creating a path that swings back and forth 5 times.
And the result of the test is
1864.394777794176 != 1248.35Which is pretty far off from the actual distance of linestring.I suppose that the reason is - I'm not using right CRS for meters projection.
