I'am trying to utilize osm2po as java lib for calculation of distances matrix between some set of points (lat/lon) and for each pair of points I call the following method that code is based on sample provided at osm2po.de web-site:
public int getDistance(GeoPoint source, GeoPoint target) { int res = Integer.MAX_VALUE; int sourceId = graph.findClosestVertexId(source.getLatitude(), source.getLongitude(), 1); int targetId = graph.findClosestVertexId(target.getLatitude(), target.getLongitude(), 1); router.traverse(graph, sourceId, targetId, Float.MAX_VALUE, params); if (router.isVisited(targetId)) { // Found! int[] path = router.makePath(targetId); float distKm = 0.0f; for (int segmentId : path) { RoutingResultSegment rrs = graph.lookupSegment(segmentId); distKm = distKm + rrs.getKm(); } res = (int)(distKm * 1000); } router.reset(); return res;But I noticed that it takes about 2-3 seconds per one point to calculate whole distance matrix (I have 10-25 points per matrix in average) that looks not too fast (30-60secs per matrix).Could someone advice what could be improved here - especially I am not sure in correct usage of reset() call - when actually it should be done? - it's not too much documentation on osm2po usage within java...
Also I would appreciate any performance tips to improve this code. One more guess I have is that findClosestVertexId() is expensive enough call and cashing its results for subsequent calls could improve the situation.
