I publish map services on a ArcGIS server using the typical arcpy script below. I need to better specify some service parameters. For example, the service should be available in WMS instead of KML, with anti-aliasing and some specific pooling parameters.
Is there a way to specify these parameters using some arcpy functions?
connection6546543 = 'C:/blabla/arcgis on myserver.eu (admin).ags'folder1116 = "Myfolder"def publishService(mxdPath, service_name, summary, tags): sddraft = 'C:/services/' + service_name + '.sddraft' if os.path.isfile(sddraft): os.remove(sddraft) # Create service definition draft map = arcpy.mapping.MapDocument(mxdPath) arcpy.mapping.CreateMapSDDraft(map, sddraft, service_name, 'ARCGIS_SERVER', connection6546543, True, folder1116, summary, tags) # Analyze the service definition draft analysis = arcpy.mapping.AnalyzeForSD(sddraft) # Print errors, warnings, and messages returned from the analysis print "The following information was returned during analysis of the MXD:" for key in ('messages', 'warnings', 'errors'): print '----' + key.upper() + '---' vars = analysis[key] for ((message, code), layerlist) in vars.iteritems(): print ' ', message, ' (CODE %i)' % code print ' applies to:', for layer in layerlist: print layer.name, print # Stage and upload the service if the sddraft analysis did not contain errors if analysis['errors'] == {}: print 'Create service definition...' sd = 'E:/services/' + service_name + '.sd' if os.path.isfile(sd): os.remove(sd) arcpy.StageService_server(sddraft, sd) print 'Publish service...' arcpy.UploadServiceDefinition_server(sd, connection6546543) print "Service successfully published" print 'Clean sd' if os.path.isfile(sd): os.remove(sd) else: print "Service publication failed: Errors during analysis." print arcpy.GetMessages() print 'Clean sddraft' if os.path.isfile(sddraft): os.remove(sddraft)Detailed solution
The detailed solution I developed with the answers is the code snippet below. It has to be inserted between the draft service creation and draft service analysis. It modifies some parameters (UsageTimeout, KML off and WMS on, etc.) but can easily be adapted to others.
import xml.dom.minidom as DOM (...)# change service parametersdoc = DOM.parse(sddraft)keys = doc.getElementsByTagName('Key')for key in keys: if key.firstChild.data == 'UsageTimeout': key.nextSibling.firstChild.data = 6000 if key.firstChild.data == 'WaitTimeout': key.nextSibling.firstChild.data = 60 if key.firstChild.data == 'IdleTimeout': key.nextSibling.firstChild.data = 20000 if key.firstChild.data == 'MinInstances': key.nextSibling.firstChild.data = 1 if key.firstChild.data == 'MaxInstances': key.nextSibling.firstChild.data = 1services___ = doc.getElementsByTagName('TypeName')for service__ in services___: if service__.firstChild.data == 'KmlServer': service__.parentNode.getElementsByTagName('Enabled')[0].firstChild.data = 'false' if service__.firstChild.data == 'WMSServer': service__.parentNode.getElementsByTagName('Enabled')[0].firstChild.data = 'true'# save changesif os.path.exists(sddraft): os.remove(sddraft)f = open(sddraft,"w")doc.writexml(f)f.close()
