I am mapping the distribution of 325 bird species, displaying circles in the grid cells each species occurs in. The data contains as many duplicates of the NAME as there are cells in which it occurs. I produce a map by filtering for a NAME then want to print the maps using the NAME field in a label as a caption below the map. I would like to have it generated automatically rather than write it in manually - in anticipation of being able to generate all species maps as an Atlas (that's another issue).So far, all I get by using [% name %] is [name], not the species name. Any ideas of what I might be missing? Nothing I've found by searching has helped so far. Many thanksNiven
