How to set extent of spatial SQL query in python (geoalchemy)
since days i've been hustling around trying to figure out, how to properly query data from a PostGIS database using geoalchemy2, an extension to python's sqlalchemy supporting spatial database operations.
I'm working with python3.4 and Openstreetmaps data from Brandenburg (admin area within Germany) that i fed into my local Postgres-DB. Data is in lat/long. I've been following the tutorials on how to set things up using the ORM part of the geoalchemy package (https://geoalchemy-2.readthedocs.org/en/latest/orm_tutorial.html). In the beginning, everything went fine
  1. Define a mapping
    Base = declarative_base()class QuerySchema(Base): __tablename__ = "brandenburg_polygon" osm_id = Column(Integer, primary_key=True) name = Column(String) amenity = Column(String) way = Column(Geometry('POLYGON'))
  2. Define DB setup
    engine = create_engine('postgresql+psycopg2://postgres_andi:{pwd}@localhost/osm'.format( pwd=keyring.get_password('osm', 'andi_postgres')))Session = sessionmaker(bind=engine)session = Session()
  3. Do my query
    buildings = session.query(QuerySchema)
Now, everything is working fine until i try to reduce the extent - for i don't want to have all buildings stored inside my DB but maybe only those within a given boundary or a boundary polygon.
  1. Reduce the extent by defining a boundary box (WKT-format)
    bbox = 'POLYGON ((13.01881424267171 52.50091209200498, 13.01881424267171 52.57800809377812, 12.87181701302189 52.57800809377812, 12.87181701302189 52.50091209200498, 13.01881424267171 52.50091209200498))'
I tried using .filter() with various options but it didn't work out. So far i understood, that filter() needs some kind of bool input, so one has to define a statement according to that. So what is wrong with a statement like this?
session.query(QuerySchema).filter(func.ST_Contains(bbox, QuerySchema.way))Checking the result of func.ST_Contains(bbox, QuerySchema.way) brings so obviously filter() won't work properly.
Question: How do I have to perform the operation to work properly, i.e. giving me only those DB entries within a given boundary?
