I have created a multiversioned view in Oracle Database 11g Enterprise Edition Release 11.2.0.3.0 - Production. I can access a specific version using a SQL script in SQL Developer. However, using other tools, I can only access DEFAULT.
The following script works fine:
call sde.version_util.set_current_version('MY_VERSION');select * from mv_my_view;Encapsulating this logic inside an Oracle View (something similar to Jay Cummins' answer to this question would be a great solution, but I cannot see a way to put a call inside a view).
In Crystal Reports, I can add SDE.VERSION_UTIL.SET_CURRENT_VERSION as a table, but cannot use it to set the version. If I specify a known good version, I get a Query Engine Error: 'Cannot obtain error message from server.'
In contrast, if I specify a non-existent version (with a typo, for example), I get an 'HY000:[Oracle][ODBC][ORA]ORA-20126: Version x not found... ORA-06512'
How can I set the current version to something other than DEFAULT for tabular reporting purposes - either in an Oracle View, or using Crystal Reports, or using some other tool?
