How to select points within a certain distance from a line?
I have a file with a points layer and a lines layer. I would like to select only the points that lay within certain distance (a couple of meters) of the lines.
Is there an easy way to do this? Or should I create a new polygone layer wich forms a kind of buffer around te lines and then use the select bij location tool? How can I create such a layer?
Thanks for your help!Dianne
