I am working with the leaflet, where we first load the imageoberlay to the map using user input.
Now, i been trying different methods to select that layer by default.
The problem is only that the first layer not loaded on map until i click on the radio button.
How can i select layer by default. I am doing something like :
Script
// New layergroup, note it's not added to the map yet var layerGroup = new L.LayerGroup(), imageOverlayUrl = firstImage, // New imageoverlay added to the layergroup imageOverlay = new L.ImageOverlay(imageOverlayUrl, bounds).addTo(layerGroup), // New featuregroup added to the layergroup featureGroup = new L.FeatureGroup().addTo(layerGroup); //dynamic method for adding new layer var layerGroupings = { "Main": layerGroup }; var layerControl = new L.control.layers(layerGroupings, null, { collapsed: false }); layerControl.addTo(map); When new layer loaded, it should be selected by default, how can i do that. If someone can help.thanks in advance
Script
