How to remove temporary layer source files in QGIS
I am new to QGIS and python.
Titles says it all. I'm modifying a plugin that creates some temporary files (layers) during it's run and I need to loop it a couple times. The algorithm works fine for the first 2 loops then it crashes (usually with a "Bad file descriptor" error). I believe the fact that it's creating all those extra files is causing problems, because even if I run the unmodified version of this algorithm a couple of times the 3rd run always gives me an error.
In more detail what I'm doing. I am modifying the ConcaveHull algorithm so that instead of just taking all the features from a layer and making one big hull for all of them, the user has the option to group the features from input layer by their values in a chosen field and make a separate hull for each group.I use a separate layer (assistant_layer) and copy features from a chosen group onto it, then I feed the layer into the code of unmodified ConcaveHull as the input layer (that part works right), it does its thing, at the end I simply remove all features from my assistant_layer and move onto the next group.
Suspect parts of the code:
#dissolve all Delaunay trianglesprogress.setText('Dissolving Delaunay triangles ...')dissolved = processing.runalg("qgis:dissolve", delaunay_layer, True, '', None)['OUTPUT']dissolved_layer = processing.getObject(dissolved)#save resultprogress.setText('Saving data ...')feat = QgsFeature()dissolved_layer.getFeatures(QgsFeatureRequest().setFilterFid(0)).nextFeature(feat)writer = self.getOutputFromName( self.OUTPUT).getVectorWriter(layer.pendingFields().toList(), QGis.WKBPolygon, layer.crs())geom = feat.geometry()On the 3rd iteration the code crashes on either the "dissolved_layer = processing.getObject(dissolved)" line with the "Bad file descriptor" error or (in rare cases) on "dissolved_layer.getFeatures(QgsFeatureRequest().setFilterFid(0)).nextFeature(feat)" with an error message "'NoneType' object has no attribute 'getFeatures'"
At the end of each loop I delete the writer using "del writer".
