How to Remove return/newline (\n) character from Field using Python and Field Calcula
I have a geodatabase table with a field that I'm trying to remove return characters (new line). I found this post (How can I remove (chomp) a newline in Python?) of how to do it, however it is not working within field calculator. Here are the code snippets that I tried:* Note return character is not at the end of the string.
!myField!.rstrip()OR
!myField!.rstrip('\n')OR
!myField!.rstrip('\r\n')OR
!myField!.replace('\n', '')000539 error given for this option:
Description The calculation used by the Calculate Field or Calculate Value tool is invalid. This error message provided will list the specific Python error.
Solution This error code covers a number of Python errors:
Example error 1: exceptions.TypeError: cannot concatenate 'str' and 'int' objects. The above is a Python-specific error. The calculation is attempting to add or concatenate a string and a number.
Example error 2: Invalid field shape@distance The above is an error using the geometry object. The distance method is not a valid method of the geometry object.
For specific Python issues, consult the external Python help for more information, or consult the Calculate Field or Calculate Value help for more information on these tools.
OR
import osdef removeReturn(myField): s = myField.rstrip(os.linesep) return sAny ideas of how to remove return characters using field calculator?
