When using RequireJS to load a JavaScript library from a CDN, an example syntax is shown at https://github.com/requirejs/example-jquery-cdn:
requirejs.config({ "paths": { "jquery": "//ajax.googleapis.com/ajax/libs/jquery/2.0.0/jquery.min" } }); How should the ArcGIS Server JS API be referenced? The page at https://developers.arcgis.com/javascript/ gives the syntax for a standard web page:
but when using RequireJS:
requirejs.config({ 'paths': { 'arcgis': '//js.arcgis.com/3.12/' } }); this returns NetworkError: 404 Not Found - http://js.arcgis.com/3.12/.js
What is the correct syntax for referencing the ArcGIS Server JS API when using RequireJS?
