How to reclassify a float raster?
I have three rasters which represent distance (in metres) from certain things (bus stops, parks, libraries). I would like to reclassify these rasters so that they get integer values based on the following criteria:
between 1 - 1000 = 1between 1000 - 2000 = 2between 2000 - 3000 = 3between 3000 - 4000 = 4between 4000 - 5000 = 5between 5000 - 6000 = 6between 6000 - 7000 = 7between 7000 - 8000 = 8between 8000 - 9000 = 99000 and above = 10I know how to do this in Spatial Analyst, but I don't have a license and I'm trying to use Open Source tools. I've attempted to use r.reclass and followed the tips in this question, but the input raster needs to be an integer raster. At the moment, my distance rasters are floats.
I've also tried using the reclassify tool in the Geospatial Modelling Environment but the input raster also needs to be an integer raster.
I've also tried using the Raster Calculator in QGIS by following this example, but it appears that that only works with a single criteria not 10.
I've been pulling my hair out trying to convert the rasters to integer, but can't figure it out.
Does anyone know how to either reclassify a float raster or convert a float raster to an integer raster?
Note, the end goal of this will be to perform a weighted overlay. Eventually, I may have Spatial Analyst in ArcGIS to do this, but I'd like to know how to do it using Open Source tools.
Thanks.
