Like feature layers have the queryAttachmentInfos() method to fetch attachment info, is there something like this to fetch attachment info from a map service (ArcGISDynamicMapServiceLayer)?
My app flow is as follows
Should i use the relationship query task? The problem with using the relationship query, i assume, would be that it would be impossible to know if the related record is an attachment or some other related record.
- query the map service based on some user defined criteria
- set info templates for the returned features (attributes + geometry) (this is also where i specify showAttachments: true but again no luck)
- add features to map.graphics and show the info window (custom popup in my case)
