I am working in ArcMap 10.3 and exporting through Data Driven Pages (DDP). The DDP export works as expected the first time, but if I use DDP to export again from the same MXD, the program hangs and I have to shut it down through the Task Manager.
I can tell if it is going to hang up as soon as I click "Export" because the Export window does not show "Page x of x" text. See screenshots here: https://geonet.esri.com/message/536459#536459. Even if I let the computer run for awhile, the "Page x of x" text never appears and the export does not happen. This only happens on the 2nd export from an MXD.
This seems to happen whether I export a single page or the entire document the first time. Sometimes if I hit "Save" right before I export it does not hang the second time. However if I resave the MXD with a new name and then export, it always hangs up and requires ArcMap to be restarted.
Someone else had this problem as asked on GeoNet here: https://geonet.esri.com/thread/161564No solutions were presented to her question so I wanted to ask again here.
Is there any way to prevent ArcMap hanging up on the second DDP export?
