How to place an numpy array into GeoTIFF image using python-gdal
I am attempting to export data of varying scales into GeoTIFF images...a new method for me. The problem I'm running into is when using the GDT_Byte pixel type, data values < 0 and > 256 are not represented (they are black or white), and when I use GDT_Float32 or other pixel types, I get white, or transparent images. How can I represent a wider range of values?
This example creates an image with values of zero of less being black, and greater then 256 being white. Alternate pixel types result in transparent images.
from osgeo import gdal, osr, ogrimport numpy as np#create a bogus gridmag_grid = np.arange(-500, 500, .1).reshape((100, 100))lats = np.arange(-10,90,1.)lons = np.arange(-10,90,1.)xres = lons[1] - lons[0]yres = lats[1] - lats[0]ysize = len(lats)xsize = len(lons)ulx = lons[0] - (xres / 2.)uly = lats[-1] - (yres / 2.)driver = gdal.GetDriverByName('GTiff')ds = driver.Create('output.tif', xsize, ysize, 1, gdal.GDT_Byte, )###################################pixel type of gdal.GDT_Float32 results in transparent image################################### this assumes the projection is Geographic lat/lon WGS 84srs = osr.SpatialReference()srs.ImportFromEPSG(4326)ds.SetProjection(srs.ExportToWkt())gt = [ulx, xres, 0, uly, 0, yres ]ds.SetGeoTransform(gt)outband=ds.GetRasterBand(1)outband.SetStatistics(np.min(mag_grid), np.max(mag_grid), np.average(mag_grid), np.std(mag_grid))outband.WriteArray(mag_grid)ds = None
