I have an application, which creates a GeoJSON stream on the server, which is then rendered on the client (using CesiumJS). GeoJSON is created using GeoTools.
I want to pass some custom data to the client about a particular point. This custom data will determine, how the client renders that point.
I add points using this code:
protected void addPoint(final double lon, final double lat, final GeometryBuilder builder, final SimpleFeatureBuilder fbuilder, final List features) { final Point point = builder.point(lon, lat); fbuilder.add(point); final SimpleFeature feature = fbuilder.buildFeature(null); features.add(feature);}If I wanted to add a string property to GeoJSON, with, say, name id and value fooBar123.
How do I do it in Java (how can I modify the code above in order for id:fooBar123 to appear in the results GeoJSON string) ?
