How to measure distance between two coordinate pairs taken from NMEA file?
In order to measure momentary speed, first I need to measure the distance between two pairs of coordinates. That's where my lack of knowledge stops me.
I have example data in NMEA format:
$GPGGA,002246,3918.5986,N,11954.1140,W,1,08,2.3,2697.9,M,-22.4,M,,*4C(...)$GPGGA,002248,3918.5887,N,11954.1395,W,1,08,2.4,2696.5,M,-22.4,M,,*42I figured out that data above gives me following information, needed to measure the distance:
    • Coordinates: 39 deg 18.5986' N, 119 deg 54.1140' W
    • Altitude (above sea level): 2697.9 m
    • Height of geoid above WGS84 elipsoid: -22.4 m
    • Coordinates: 39 deg 18.5887' N, 119 deg 54.1395' W
    • Altitude (above sea level): 2696.5 m
Angular distance between this two points is: latitude -0,0099', longitude 0.0255'.The difference between altitudes is -1,4 m.
And there I'm stuck. And my question is - how to measure the distance between those two points in (kilo)meters?
