How to make a point from real latitude and longitude values
My program has a center point and one moving object . At this moment this point is somewhere in Europe.But Now i have to change that point from the latitude and longitude values(of Australia) . Please see This program . from that program i could make program running .
CODE PART`
using System;using System.Collections.Generic;using System.ComponentModel;using System.Data;using System.Drawing;using System.Text;using System.Windows.Forms;using GeoAPI.Geometries;using NetTopologySuite.Geometries;using SharpMap.Layers;using SharpMap.Data;using SharpMap.Styles;using SharpMap.Rendering.Thematics;using BruTile.Web;using WindowsFormsApplication1.Properties;#if DotSpatialProjectionsusing GeometryTransform = DotSpatial.Projections.GeometryTransform;#elseusing GeometryTransform = GeoAPI.CoordinateSystems.Transformations.GeometryTransform;#endifnamespace WindowsFormsApplication1{ public partial class FormMovingObjectOverTileLayer : Form { private List geos = new List(); private bool movingUp = true; private bool movingLeft = true; GeoAPI.Geometries.Coordinate position; public FormMovingObjectOverTileLayer() { InitializeComponent(); this.SetStyle(ControlStyles.DoubleBuffer | ControlStyles.UserPaint | ControlStyles.AllPaintingInWmPaint, true); this.UpdateStyles(); } private void FormMovingObjectOverTileLayer_Load(object sender, EventArgs e) { //Lisbon...#if DotSpatialProjections var mathTransform = LayerTools.Wgs84toGoogleMercator; var geom = GeometryTransform.TransformBox( new Envelope(-9.205626, -9.123736, 38.690993, 38.740837), mathTransform.Source, mathTransform.Target);#else var mathTransform = LayerTools.Wgs84toGoogleMercator.MathTransform; GeoAPI.Geometries.Envelope geom = GeometryTransform.TransformBox( new Envelope(-9.205626, -9.123736, 38.690993, 38.740837), mathTransform);#endif //Google Background TileAsyncLayer layer2 = new TileAsyncLayer(new OsmTileSource(), "TileLayer - OSM"); this.mapBox1.Map.BackgroundLayer.Add(layer2); var gf = new GeometryFactory(new PrecisionModel(), 3857); //Adds a static layer var staticLayer = new VectorLayer("Fixed Marker"); //position = geom.GetCentroid(); var aux = new List(); aux.Add(gf.CreatePoint(geom.Centre)); staticLayer.Style.Symbol = Resources.PumpSmall; var geoProviderFixed = new SharpMap.Data.Providers.GeometryProvider(aux); staticLayer.DataSource = geoProviderFixed; this.mapBox1.Map.Layers.Add(staticLayer); //Adds a moving variable layer VectorLayer pushPinLayer = new VectorLayer("PushPins"); position = geom.Centre; geos.Add(gf.CreatePoint(position)); pushPinLayer.Style.Symbol = Resources.ZoomToExtents1; var geoProvider = new SharpMap.Data.Providers.GeometryProvider(geos); pushPinLayer.DataSource = geoProvider; this.mapBox1.Map.VariableLayers.Add(pushPinLayer); this.mapBox1.Map.ZoomToBox(geom); this.mapBox1.Refresh(); } private void timer1_Tick(object sender, EventArgs e) { double dx, dy; if (movingLeft) dx = -100; else dx = 100; if (movingUp) dy = 100; else dy = -100; position.X = position.X + dx; position.Y = position.Y + dy; if (position.X < this.mapBox1.Map.Envelope.MinX) movingLeft = false; else if (position.X > this.mapBox1.Map.Envelope.MaxX) movingLeft = true; if (position.Y < this.mapBox1.Map.Envelope.MinY) movingUp = true; else if (position.Y > this.mapBox1.Map.Envelope.MaxY) movingUp = false; VariableLayerCollection.TouchTimer(); //this.mapBox1.Refresh(); } private void button4_Click(object sender, EventArgs e) { this.timer1.Enabled = true; } private void button1_Click(object sender, EventArgs e) { this.timer1.Enabled = false; } private void Form2_SizeChanged(object sender, EventArgs e) { this.mapBox1.Refresh(); } private void FormMovingObjectOverTileLayer_FormClosing(object sender, FormClosingEventArgs e) { this.timer1.Stop(); } }}`
