How to interpret svg:transform element
I'm rendering maps into SVG files, and I'd like to put geographic metadata into those files, as described in section 7.13 and 7.14 of the SVG spec, but I'm uncertain about how to interpret the element.
My primary use case for this is to eventually get the information into a GeoTIFF file. Since I have full control over the rendering chain, I could convey this information by any sneaky means that I care to invent, but since there is a documented way of doing it...
Let's take a concrete example:
I'm drawing my map on A4-sized paper, and I have set up the viewBox so that the viewBox coordinate system gives me 90 units per inch. In other words, the top left corner of the paper is at (0, 0) and the lower right corner is at (744, 1052).
My geographic data is in EPSG:3006 (SWEREF99TM, more or less equivalent to EPSG:32633), so a typical point P could be (660000, 6612000). Possibly, those coordinates should be flipped, but that's a separate can of worms -- this is what works with PostGIS, so it is what I have.
I want a scale of 1:50000, and the lower left corner of the map at (655000, 6606000). This puts my point P roughly at the centre of the page.
I want a sane coordinate system on my page, so I wrap the entire map in
thus putting the origin at lower left, and Y axis upwards.
I then compute coordinates for my point in this coordinate system:
x = ( 660000 - 655000) / 50000 * 90 / 0.0254 = 354y = (6612000 - 6606000) / 50000 * 90 / 0.0254 = 425And finally I draw my point as a small circle
(In reality, I keep a few more decimals.)
Now, what should I put in to describe this? Should I describe the transform from geographic coordinates to the actual numbers written into the file, i.e.
scale(0.0709) translate(-655000 -6606000) or should I describe the transform to viewBox space
translate(0 1052) scale(1 -1) scale(0.0709) translate(-655000 -6606000)or something completely different?
