How to import ArcGIS 10.1 File geodatabase to MS SQL Server 2012?
I would like to import my File Geodatabase from ArcGIS 10.1 into MS SQL Server 2012.
I have never done it before, so I expect to do the import the same way as import data from excel table.
Problem is when I open MS SQL Server Import wizard and as a data source I choose Esri geodatabse OLE DB provider - an error occured:
ClassFactory cannot get required class. (Microsoft OLE DB Service Components)
Please does anybody know what I´m doing wrong, or is there some easiest way, for example with ArcSDE?
