How to Identify layers from multiple ArcGIS Server instances
This applies to ArcGIS Server 9.3 with the JavaScript API 2.4.
My goal is to click on the map and have the Identify task run on all visible Dynamic layers.
IdentifyTask requires a URL to the REST endpoint, with IdentifyParameters specifying which layerIds the identify operation should be performed on.
It seems the Identify tool is expecting all layers to be accessible from the same REST endpoint (ie, the same ArcGIS Server).
In my case, layers are being served from multiple ArcGIS Server instances - how can the Identify tool support this? For example, if the Buildings and Parcels layers in this map were coming from separate ArcGIS Servers.
(This is related to my previous question, but I realise now I need to answer this question first)
