I need to calculate the location of polygons along the route in ArcGIS (ArcInfo) 9 or 10. What I have already found out is only the calculation of the start and end of the intersection of a polygon with the route. But in my case I need to attribute all the polygons along the route, many of them do not intersect the route at all. The route is one and continuous.
I would need (at best) to get the following values:
- Route measure of the polygon starting (aside from the route, by the shortest perpendicular line)
- Route measure of the polygon ending (same)
- Distance of the nearest polygon edge from a route (given that the polygon does not intersect the route)
- Distance of the farthest polygon edge from a route
- Measures to be specified left or right side from the route (as the route measures increase) - probably +/- values
